multiple solutions
Posted 1 sept. 2011, 07:30 UTC+2 Version 4.2 1 Reply
Hi all,
I have a model (electric currents), that I need to solve many times. In my model, everything remains the same, but the source location. So I need multiple solutions for each source location.
From the results I need the following
1) Potential in some nodes
2) The integral of the dot product between the current density, from different source locations ( like int(Jx1*Jx2), where Jx1 is the current density when source is at location 1, and Jx2 when source is at location 2.
The way I am trying to solve this, is one of the following
1) The obvious way to do that is to add many physics in my model, where everything remains the same, but the source location. But this approach requires to define the properties on each physics, the boundary conditions (although it is the same everywhere). It is very time consuming.
2) I read in comsol forums, that although I could create multiple studies, and get results, those results do not interact with each other (like I can’t even many a subtraction of V1-V2, for two different solutions).
3) To create different models, one for each solution. But this way, I still don’t know if I cwill be able to calculate the integral.
4) Parametric solver, where the location of source is a variable. Can I do that?
Which method would you propose?
Thanks in advance.
Thanks in advance.
1 Reply Last Post 2 sept. 2011, 20:53 UTC+2
