plots during compute
I made this modell: Cold water is flowing through a pipe which is heating it up.
The Problem doesn't converge and stops after a couple iterations.
So I have following question: Is it possible to build up a result plot for each iteration step. Maybe it helps to debug the modell.
The study is stationary.
If you need more informations, please feel free to ask. I'm using Comsol just for 4 days now.
Thanks a lot
1 Reply Last Post 1 sept. 2011, 14:22 UTC+2
Michael Rembe Certified Consultant
Posted: 1 decade ago 1 sept. 2011, 14:22 UTC+2
If you use COSMSOL 4.x click on the solver node and look for "results while solving". You can find this item at several nodes, that means you get a result plot at different levels of the solver. First you have to define a plot (probe plot or result plot) what you want to see.
Michael
If you use COSMSOL 4.x click on the solver node and look for "results while solving". You can find this item at several nodes, that means you get a result plot at different levels of the solver. First you have to define a plot (probe plot or result plot) what you want to see. Michael
