Getting different values each time running the same simulation
Hello all,
I am working on Comsol 5.3, using a time dependent ion flow model with 2 Partial differential equations. Everytime I run the same simulation (without any change) i get totally different graphs. Can anybody pls suggest me ways to solve this issue. Thank you so much..
With best regards Hari
2 Replies Last Post 4 janv. 2019, 15:39 UTC+1
Posted: 7 years ago 1 janv. 2019, 06:29 UTC+1
Updated: 7 years ago 1 janv. 2019, 06:31 UTC+1
That's strange. By any chance, do you have (or did you define) any random number generators in your problem? That would be my first guess, since that would do it. But if not, then I am curious: Does it give different results if you clear the solution before you recompute? Does it give different results if you shutdown Comsol Multiphysics and then restart it? Does it give different results if you restart your computer between runs? How about if you save the file with two different names, load them both at the same time, and execute them both? Maybe you should post your model file to the forum!
-- Happy New Year.
That's strange. By any chance, do you have (or did you define) any random number generators in your problem? That would be my first guess, since that would do it. But if not, then I am curious: Does it give different results if you clear the solution before you recompute? Does it give different results if you shutdown Comsol Multiphysics and then restart it? Does it give different results if you restart your computer between runs? How about if you save the file with two different names, load them both at the same time, and execute them both? Maybe you should post your model file to the forum! -- Happy New Year.
Josh Thomas Certified Consultant
Posted: 7 years ago 4 janv. 2019, 15:39 UTC+1
I would check Initial Values of Variables Solved For. Are you sure each time you click compute you are starting from the same initial conditions?
Josh Thomas
AltaSim Technologies
