creating geometry in matlab-function different from current matlab-function
Posted 28 sept. 2011, 17:02 UTC−4 Interfacing, Geometry Version 4.2 1 Reply
i'm tying to use an external matlab-function to create a certain geometry and then assign this geometry to my current model in matlab.
Unfortunately something like the following doesn't work:
model.geometry('myGeometry') = geometryCreationMatlabFunction(param1,param2);
I couldn't find any feature that allows me to import/copy/assign geometries from model B into an existing comsol model A (i also want to avoid saving the geometry as a file and then reimport the whole stuff).
Is there an easy way to get this done?
Udate:
I finally figured out how to do it. All you need to to is create a model in the curent m-file. Then give this model as argument to the external m-file. The external m-file now does something with the model like setting up geometry etc. After that it gives back the model as return value. Thats all :)
Hello Chris Shor
