Phase change and Fluid flow.
Posted 28 mars 2019, 20:54 UTC+1 Computational Fluid Dynamics (CFD), Heat Transfer 0 Replies
Hi im trying to simulate a process in wich Ethylene Glycol is heated beyond the boiling point (inducing phase change). I need to evaluate the phase change, and the fluid flow due to the change in density of this process. The problem I'm facing is that it looks like if there is a phase change, the fluid flow due to the phase change has a sudden change and this makes the simulation not converge. I've tried coupling with non-isothemal flow and it runs until the model reaches boiling temperature. I've used laminar flow and turbulent k-epsilon model. The thing is all the examples I've seen from the comsol page or the community where there is a two phase flow and its not bubbly, they ussually use Level Set, Moving Mesh or Phase Field as the interfase tracking method but in my case I don't have an initial interfase defined given that it is created when the fluid boils. Also the time-scale is in nanoseconds and lenght-scale is in micrometers for this problems.
Hello Enrique Santana
