what's the meaning/definition of initial magnetic susceptibility
hello! I am studying the ''non linear_magnetostriction'' model in COMSOL. I'm confused about the meaning of "initial" in "initial magnetic susceptibility", whcih is a parameter of magnetostrictive material. Does it mean the magnetic susceptibility will change over time? But the study type is stationary, which means varibles do not change over time, so does initial magnetic susceptibility equal to magnetic susceptibility? thanks!
Regards Yi
4 Replies Last Post 5 mai 2019, 09:16 UTC−4
Posted: 7 years ago 25 avr. 2019, 05:43 UTC−4
Hi Yi,
'initial' is not related to time but to small fields close to zero.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Yi, 'initial' is not related to time but to small fields close to zero. Cheers Edgar
Posted: 6 years ago 5 mai 2019, 07:52 UTC−4
Hi Yi,
Cheers Edgar
Hello, Mr.Edgar Thank you very much for your reply. I still don't know the meaning of 'small fields close to zero'. I found that the initial magnetic susceptibility is larger, the magnetostriction is larger. how does initial magnetic susceptibility influence the magnetostriction? In addition, i haven't seen initial magnetic susceptibility in related paper, but i've seen magnetic susceptibility, are they the same? thanks a lot.
regards Yi
>Hi Yi, > >'initial' is not related to time but to small fields close to zero. > >Cheers >Edgar Hello, Mr.Edgar Thank you very much for your reply. I still don't know the meaning of 'small fields close to zero'. I found that the initial magnetic susceptibility is larger, the magnetostriction is larger. how does initial magnetic susceptibility influence the magnetostriction? In addition, i haven't seen initial magnetic susceptibility in related paper, but i've seen magnetic susceptibility, are they the same? thanks a lot. regards Yi
Posted: 6 years ago 5 mai 2019, 09:12 UTC−4
Updated: 6 years ago 6 mai 2019, 08:25 UTC−4
Look there: https://en.wikipedia.org/wiki/Rayleigh_law
Edgar J. Kaiser
www.emphys.com
Posted: 6 years ago 5 mai 2019, 09:16 UTC−4
I tried to post a link, but the forum software obviously doesn't allow that any longer. Try searching for 'Rayleigh law' and 'magnetics'. And you already found it by yourself. For small fields the magnetic susceptibility is different from large fields.
Edgar J. Kaiser
www.emphys.com
