Units problem
I am trying to set up a model about endothermic reaction in a tube reactor. Hydrogen is produced in the process of reaction. When I used -k*c_A*deltaH to express heating source, the program regarded the unit was wrong. Also, when I used 3*k*c_A to express the production of hydrogen, the progran again regarded the unit was wrong. Can anybody explain why?
Thank you very much.
2 Replies Last Post 27 oct. 2011, 20:00 UTC+2
Posted: 1 decade ago 27 oct. 2011, 19:24 UTC+2
I suppose it all depends what are the units of your variables and where you used them. I believe you should dump an image at least with some more details to give us a better clue. many fields in COMSOL are "per element dx*dy*dz) hence the demand for density units
Hi I suppose it all depends what are the units of your variables and where you used them. I believe you should dump an image at least with some more details to give us a better clue. many fields in COMSOL are "per element dx*dy*dz) hence the demand for density units -- Good luck Ivar
Posted: 1 decade ago 27 oct. 2011, 20:00 UTC+2
Hi Ivar,
Thank you for the quick response. I have solved the problem.
Xuxian
Hi Ivar, Thank you for the quick response. I have solved the problem. Best regards, Xuxian
