Min & max graph
Hi people,
I'm simulating the heating of a wooden beam, with a time dependent study.
Now I must make a graph of the trend of minimun, mean and maximum temperature with time.
How can I do it?
many thanks in advance
Roberto
1 Reply Last Post 27 oct. 2011, 22:17 UTC+2
Posted: 1 decade ago 27 oct. 2011, 22:17 UTC+2
well what if you do an indexed search on the doc with "minimum plot" ? You can add a solution being the average, min or max value of a given part (add a selection subnode) nd then plot the resultsin a plot group with i.e. all three on te same 1D line graph (but what are you using on the X coordinate ?)
Hi well what if you do an indexed search on the doc with "minimum plot" ? You can add a solution being the average, min or max value of a given part (add a selection subnode) nd then plot the resultsin a plot group with i.e. all three on te same 1D line graph (but what are you using on the X coordinate ?) -- Good luck Ivar
