fully developed velocity profile for an FSI problem
Posted 28 oct. 2011, 12:44 UTC−4 Fluid & Heat, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.2 3 Replies
In COMSOL, for a laminar pipe flow problem, a fully developed velocity profile can be specified by using
umax*(1-(r/H)^2) where umax is a known constant, H is the radius of the pipe, r is the spatial coordinate in the radial direction.
But how do you specify a fully developed velocity BC when you have a fluid-structure interaction problem? It looks like I cannot use umax*(1-(r/H)^2) anymore because of the following reasons:
- when the fluid flows, it exerts a force on the solid and the solid expands. So H which was a known constant in the laminar flow problem is no longer a constant. H becomes (H+some displacement based on the solid domain). I am wondering if anyone knows how to define this displacement as an input? If I ignore the displacement then when r>H, my velocity BC is no longer fully developed. It changes and is different from what I want it to be.
- Since I don't know an answer to the above question yet, lets assume that I am considering the inlet velocity profile for a FSI problem as umax*(1-(r/H)^2). Should this be considered as umax*(1-(r/H)^2) or umax*(1-(R/H)^2). In other words, what coordiates should I use? I would think it should be spatial coordinates (r) but can someone confirm this?
Sirisha
Sirisha
3 Replies Last Post 30 oct. 2011, 08:38 UTC−4
