Exact calculation of electrical current from current density
Hello everybody,
I am using comsol to model a bipolar probe with three surfaces : Conductive surface forced to 0V, conductive surface forced to 10V and insulation surface beetween the two conductive surfaces. The probe is put on sea water.
So when i resolve my system I have streamlines between the two condictive surfaces.
Now, I want to calculate the current on each conductive surface from the current density integration. I use the following expression ( ec.Jxnx+ec.Jyny+ec.Jz*nz ).
I have a difference between the current IN and the current OUT about 1%. So I change the mesh to have a more accurate result but I realized that the current is totaly different comparing to the first mesh. So for one kind of mesh I have different current values.
Someone can help me if he have any idea.
Thank you very much
4 Replies Last Post 15 mai 2019, 13:34 UTC+2
Posted: 6 years ago 10 mai 2019, 13:49 UTC+2
I would recommend to perform a mesh convergence study to find out what mesh resolution is needed for consistent results.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, I would recommend to perform a mesh convergence study to find out what mesh resolution is needed for consistent results. Cheers Edgar
Posted: 6 years ago 10 mai 2019, 14:13 UTC+2
I also recommend reading the Computing Accurate Fluxes section of the COMSOL reference manual it's a very interesting and useful read. You'll find the the reference manual at
/path/to/comsol/multiphysics/doc/pdf/COMSOL_multiphysics/
The file is
COMSOL_ReferenceManual.pdf
I also recommend reading the **Computing Accurate Fluxes** section of the COMSOL reference manual it's a very interesting and useful read. You'll find the the reference manual at /path/to/comsol/multiphysics/doc/pdf/COMSOL_multiphysics/ The file is COMSOL_ReferenceManual.pdf
Posted: 6 years ago 13 mai 2019, 09:48 UTC+2
Thank you Edgar and Alexis for recommandations. I do that and I keep you informed. Lyes
Posted: 6 years ago 15 mai 2019, 13:34 UTC+2
I tried reacf(V) on a known physic and I have the most accurate electrical current.
Thank you Alexis and Edgar Lyes
Hello, I tried reacf(V) on a known physic and I have the most accurate electrical current. Thank you Alexis and Edgar Lyes
