How to simulate AC Multi-turn coil numeric
I want to simulate the result as changing inductace of coil in an active eddy current sensor with different material target. The Multi-turn coil numeric fuction is selected to simulate regtangular coil geometry. I use two steps in simulaiton; step1 Coil Geometry Analysis and step2 Frequency Domain. However, I cannot find the coil inductance parameter in results. There are only coil current and coil resistance DC.
Can anyone guide me to solve this problem?
Note that I follow the example of using Multi-turn coil numeric with Alternative Current in https://www.comsol.de/forum/thread/attachment/214261/3D_Coils_43a-45831.pdf. However, there is only DC simulation case in that example.
Thank
2 Replies Last Post 23 mai 2019, 13:25 UTC+2
Posted: 6 years ago 21 mai 2019, 08:11 UTC+2
in a frequency domain setup with a numeric coil in mf-physics I see all the coil parameters in the results section.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, in a frequency domain setup with a numeric coil in mf-physics I see all the coil parameters in the results section. Cheers Edgar
Posted: 6 years ago 23 mai 2019, 13:25 UTC+2
Dear Edgar,
Thank you very much. I found it.
Siripong
Dear Edgar, Thank you very much. I found it. Siripong
