Results quite different from 3.5a to 4.2 with same file
Posted 10 nov. 2011, 03:10 UTC+1 Fluid & Heat, Computational Fluid Dynamics (CFD), Results & Visualization, Studies & Solvers Version 3.5a, Version 4.2 1 Reply
Hi folks!
I was wondering if someone has some insight on a particular matter of opening files created with 3.5a and opening them in version 4.2.
I will explain further: I have a file from a previous colleague and I need to use it in 4.2. There is a BIG problem however, the file will run in 3.5a and converge to a solution that concurs with experimental data. When I opne the file in version 4.2 (the files opens with no problem) and I run the simulation I get an error stating that the number of iterations has been reached and no solution is presented.
So I change the number of iterations and after a while I get some results but they are nowhere near the solution obtained with version 3.5a.
Coul somenone provide some insight or advice on this matter? I have been trying to understand where the error is occuring and I have to admit that i'm lost on this one...
Hope clearer minds are out there ;)
Best Regards,
Rui
Best Regards,
Rui
1 Reply Last Post 10 nov. 2011, 07:23 UTC+1
