Some fluid disappear during the simulation on two phases flow model.
I'm working on the simulation of electrospinning.
My problem, the droplet from the nozzle going down so some fluid disappear. A part of my fluid going into the inlet which is normally impossible because my inlet is flow rate. You can see easily if you run my simulation.
If you have some subjection to fix this problem.
Max.
1 Reply Last Post 6 déc. 2011, 02:01 UTC+1
Posted: 1 decade ago 6 déc. 2011, 02:01 UTC+1
Maybe it's an over problem but my simulation still not working. I can't understand, I use exactly the same value from a paper (I attached). I can't found were I made a mistake so please can you help me. I'm really disappointed.
Max.
Maybe it's an over problem but my simulation still not working. I can't understand, I use exactly the same value from a paper (I attached). I can't found were I made a mistake so please can you help me. I'm really disappointed. Max.
