model.param.get does not return complex values
Posted 27 nov. 2011, 11:43 UTC+1 Parameters, Variables, & Functions Version 4.2a 3 Replies
I set a parameter to a complex value by:
model.param.set('v1', 4.5+j*2)
However, when I try to access the parameter later by
model.param.get('v1')
All I get is
4.5
I am using comsol4.2a and matlab 2011a on a 64 bit linux machine.
Does the error occur when I am setting the parameter value or when I am accessing it.
In other words, is 'v1' correctly set to the complex value, and it is just the model.param.get that is not
working properly?
Or, is it model.param.set which is not setting 'v1' correctly?
I would appreciate any help.
Thank you,
Emi
All I get is
4.5
working properly?
Thank you,
Emi
3 Replies Last Post 28 nov. 2011, 07:15 UTC+1
