Model of 3D electromagnet
Posted 29 nov. 2011, 21:48 UTC−5 Low-Frequency Electromagnetics, Mesh Version 4.2a 1 Reply
Hi all,
Thank you all for reading this in advance! Let me get started by saying I'm completely new to Comsol, but have been working with some CAD (SolidWorks) and simulation/physics (Matlab) software before.
My project is about finding flaws in metal structures through various techniques. Right now I am considering to purchase a license of Comsol to use for our simulation purposes. I have just received the trial package (version 4.2a) and did some tutorials (permanent magnet and 3D inductor) but to get a better feeling about Comsol would like to start with some basic simulations of my own.
Therefore I have successfully build a very basic 3d model of a steel cylinder with copper coils (Helix) wrapped around it, all encapsulated by a sphere of air. I would like to see what the magnetic field generated by the coils around the steel would like. I am using the Magnetic and Electric Fields (mef) package and from the 3d inductor example (in the library) I think I have to specify the terminal and ground of the coil in order to send a current through it. Though I am not sure why I can not seem select these, when I select the terminal and ground point (two ends of the copper coil, right?) then it says not applicable in the boundary selection box.
Also I think I might be doing something wrong with the mesh as it takes up all of my RAM to solve the study (I can build the mesh using less then 1GB of both RAM and virtual memory) and my computer basically hangs. Just as a note, the computer I'm using has 8 GB of RAM and a high-end graphics card. It might be to fine for what i'm trying to simulate, but If I choose it bigger then I end up getting errors?
Hopefully someone here is able to let me know if I'm going in the right direction and maybe let me know what I have to look at to get this simulation working. The model that I've build is also attached.
Thank you for your time!
1 Reply Last Post 30 nov. 2011, 02:37 UTC−5
