Client/Server, Parametric sweep, "Export to File" problem
Posted 30 nov. 2011, 12:57 UTC−5 Version 4.2a, Version 4.3 2 Replies
I am running Comsol in a Client/Server mode. The server is running on Linux, the Client on Windows. I use a parametric sweep. For each iteration of the parametric sweep, I want that the *.mph file be saved, as well as several graphs/data. I therefore use the nodes "Save Model to File" and "Export to file" in my parametric sweep.
Although my client is running on Windows, I found out that I have to set the path for saving the *.mph file on the linux server. After each iteration of my parametric sweep, a *.mph file is created on the linux server.
I added the node "Export to File" in order to save additional graphs/data at each itreation. I set the filename to a location on the linux machine. It did not work. I got the following error message after the first iteration, i.e., the first time when the node "Export to File" comes into play:
"Error in sweep: Unknown property. -Property: filename."
I then changed the filename to a location on the Windows machine. This resulted in the same error message.
The problem is described in a more visual way in the attached pdf. Does anyone know what to do?
Thanks a lot. Alois
Thanks a lot. Alois
2 Replies Last Post 2 déc. 2011, 08:11 UTC−5
