FSI: Form Union vs Assembly
I have an FSI problem with multiple elastic plates floating on the surface of a fluid. When FORM UNION is used, the model fails when there occur collision between plates. I have tried FORM ASSEMBLY, with "IDENTITY BOUNDARY PAIRS" at fluid-solid interface. But I cannot select the boundary to apply the multiphysics FLUID STRUCTURE INTERACTION.
Does this means that FORM ASSEMBLY can only be applied for FLUID STRUCTURE INTERACTION, PAIR ?
Thanks and regards, Dharma
1 Reply Last Post 7 nov. 2019, 12:47 UTC+1
Posted: 6 years ago 7 nov. 2019, 12:47 UTC+1
Updated: 6 years ago 7 nov. 2019, 12:48 UTC+1
Hi Dharma,
That is correct. If it is an assembly you should use Fluid-Structure Interaction, Pair.
Henrik
Henrik Sönnerlind
COMSOL
Hi Dharma, That is correct. If it is an assembly you should use Fluid-Structure Interaction, Pair. Regards, Henrik
