Hello Siyuan Li
5 years ago
6 janv. 2020, 22:48 UTC+1
Hi Siyuan,
One reason that you are not getting the output voltage you expect can be due to the fact that you are not operating at the resonance frequency of your piezo elements. 10kHz may be far off the resonance frequency of your transducers. So, when you apply 1V of voltage to your transmitter it does not result in its maximum stress and deflection. In fact, I looked at your second model and I changed 10kHz to 1Hz and I got much higher voltages than 0.1V on the right piezo element. You can also use Frequency Domain study instead of a Time Dependent.
Hamid
Hi Siyuan,
Hamid
5 years ago
15 janv. 2020, 16:56 UTC+1
Hi Siyuan,
Hamid
Hi Hamid,
Thank you for your reply, I've tried the simulation in frequency domain. Indeed the resonance frequency is about 110kHz and before that the Amplitude of output is about 0.2V. It accords with the simulation in time domain. But when I change the frequency to 110kHz, the output is not a sin wave anymore. It's more like a triangular form. Do you know why it shows like that? Thank you very much.
Siyuan
>Hi Siyuan,
>Hamid
Hi Hamid,
Siyuan
5 years ago
21 janv. 2020, 15:26 UTC+1
Updated:
5 years ago
21 janv. 2020, 15:38 UTC+1
Hi Siyuan,
I guess when you increased the frequency from 10kHz to 110kHz, you may need more points in time to solve for. The way you define it now in your model does not do that. It just assumes the same number of points in one period. If you don't have enough points in one period of your sine wave, you may end up seeing the wave as a triangular signal rather than a sine one.
Good luck,
Hamid
Hi Siyuan,
Good luck,
Hamid
