Problem with gas in Non-Isothermal Flow (nist)
Posted 18 déc. 2011, 14:16 UTC+1 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 4.2 3 Replies
Hello
I have a problem with gases in the Non-isothermal flow module (Comsol 4.2)
To illustrate that problem, I will use the official model "Free Convection in a Water Glass" (www.comsol.com/showroom/gallery/195/) because I have created a model based on that and if one's solves the problem on that model, it will solve my problem too.
So, in the example "Free Convection in a Water Glass", if I replace the water by steam or air (from the material library), the simulation crashes and it says that no initial solution has been found. If I deactivate the Volume Force in the nist physics model (which is "-nitf.rho*g_const") it works (but it is not interesting because the gas doesn't move).
Have you any idea about the origin of the problem ?
Thank you very much.
3 Replies Last Post 19 déc. 2011, 14:04 UTC+1
