Moving mesh in FSI issues
Posted 19 déc. 2011, 01:38 UTC+1 MEMS & Nanotechnology, Fluid & Heat, MEMS & Piezoelectric Devices, Computational Fluid Dynamics (CFD), Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers Version 4.2a 0 Replies
attached model is able to get converge, however, the fluid do not deform with solid,
May I know why?
I think this is belong to post processing data, since the wall has displacement, just it separate from fluid only.
but i just cannot show the result in correct way.
Solution is in spatial mesh.
Any idea?
p/s: you may run the model to see the solution in the last 2D plot group. 0.04s. The solid side detach from fluid.OMG!
Thank you.
Hello Chiwei Ong
