Edgar J. Kaiser
Certified Consultant
5 years ago
14 janv. 2020, 19:43 UTC+1
Antonny,
I think it should rather be seen as a symmetry boundary condition than as something related to a physical material. I also have some difficulties to see where it could be useful as an internal boundary.
It is not really meant to represent a boundary into open space but can be good enough if the electric field is small at the outer boundary relative to the region of interest.
If you need to have a better approximation for open space you should use infinite element domains.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Antonny,
Cheers
Edgar
Robert Koslover
5 years ago
14 janv. 2020, 20:08 UTC+1
Updated:
5 years ago
14 janv. 2020, 20:10 UTC+1
If you are doing an electrostatic model of a finite sized region containing variously separated charges (or charged objects, or conductors at various potential differences such as capacitor plates), but (and this is important!) which has no net overall charge, then the outward (radial, if a sphere) component of the electric field must fall off very rapidly with distance from those objects, since there is no monopole term (only dipole or higher terms). This is actually a fairly common situation. A conceptual surrounding computational-volume boundary, such as a sphere (or similar) with any modest radius away from all those objects will thus have a relatively-low component of E normal to its surface. After all, the electric field lines associated with the dipole and higher order terms are (except for certain symmetry points) all closed. Since you have no choice but to work with a finite-sized computational volume, it is a reasonable approximation to assume the field at the computational boundary (again, if it is far enough away from the charges) will be (nearly) tangential to E at most/all points of interest. And that is the "zero charge" boundary condition. At least, that is what I use it for.
If you are doing an electrostatic model of a finite sized region containing variously separated charges (or charged objects, or conductors at various potential differences such as capacitor plates), but (and this is important!) which has *no net overall charge*, then the outward (radial, if a sphere) component of the electric field must fall off very rapidly with distance from those objects, since there is no monopole term (only dipole or higher terms). This is actually a fairly common situation. A conceptual surrounding computational-volume boundary, such as a sphere (or similar) with any modest radius away from all those objects will thus have a relatively-low component of E normal to its surface. After all, the electric field lines associated with the dipole and higher order terms are (except for certain symmetry points) all closed. Since you have no choice but to work with a finite-sized computational volume, it is a reasonable approximation to assume the field at the computational boundary (again, if it is far enough away from the charges) will be (nearly) tangential to E at most/all points of interest. And that is the "zero charge" boundary condition. At least, that is what I use it for.
5 years ago
15 janv. 2020, 01:44 UTC+1
Updated:
5 years ago
15 janv. 2020, 02:00 UTC+1
Dear Edgar and Robert,
Many thanks for your clarification! It all makes more sense now, especially why this condition is the default choice for external boundaries. I should have figured it out myself, actually, but those simple examples that I played with when trying to understand this kind of BC were all monopole. And for them Zero Charge external boundary condition is not at all "natural".
Still I seem to be missing some important physical points about the relation between this boundary being "zero charge" and "perfectly insulating". There is zero charge everywhere in an electrostatic model unless explicitly prescribed, right? Or may it be that there is no physical meaning that I am searching for (at least for electrostatics), and we can only talk about "mathematically" insulating boundary across which electric field cannot penetrate? (Like, for example, if it were not electric field, but a flow of a liquid it would be the other way around. Tangential velocity around an object would make perfect physical sense, while it being normal to the surface of an object would be much more difficult to interpret physically)
There seems to be another useful discussion here:
http://www.kirbyresearch.com/index.cfm/wrap/textbook/microfluidicsnanofluidicsse22.html
But they are talking about electrodynamics and still I don't quite get the point.
