21 déc. 2011, 10:57 UTC+1
it's rather important to understand the differences.
I would suggest to use structural and test the deformations of a soft solids to illustrate the difference of the spatial (deformed) frame and the material (initial) frame
Nagi Elabbasi
Facebook Reality Labs
22 déc. 2011, 05:40 UTC+1
Variables r, z refer to spatial coordinates that move with the solid (in the case of solid mechanics). Variables R, Z refer to the reference coordinates which are independent of deformation/displacement. If a point starts at z=Z=1 and moves by 0.1, then Z remains 1.0 but z becomes 1.1. Your integrals are different because they integrate over different areas.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
22 déc. 2011, 18:00 UTC+1
Thanks Ivar and Nagi!
I implemented a simple model in solid mechanics. By applying force to a elastic rectangle over time, it deformed and coordinate of its points was plotted. Indeed R and Z always remain at the same coordinate (reference coordinates: static) while r and z change over time (spatial coordinates: moving). I think this is what have told by Nagi.
Thanks for your help. :)
23 déc. 2011, 04:50 UTC+1
Hi, another thing i am would like to ask:
By plotting the deformation result in 2D plot group>surface (total deformation) and deformation (displacemnt field), I found that plot data set edge (black border line: in spatial frame) does not match with the edge of colour plot deformation (as shown in attached solid_displacement.png). I thought they should match each other?
23 déc. 2011, 10:11 UTC+1
well if you add the displacement ot an already "displaced" deformation you get it double up, this was an issue in 3.5 as you needed to uncheck the disp when turning on the spatial frame, but normally it's treated correctly in v4 (apart if you are tweaking the equations such that COMSOL does not understand)
Nagi Elabbasi
23 déc. 2011, 14:06 UTC+1
It’s either what Ivar just described above or you are scaling the deformation field in this plot. In that case, setting the deformation scaling factor to 1.0 should match the two plots.
23 déc. 2011, 15:32 UTC+1
Yea, it works after changing the deformation scale factor to 1.0! Thank you again, Ivar and Nagi!
