accessing MATLAB global variables when running models in MATLAB
I have defined an external function in matlab that I use in my Comsol/Matlab livelink model to set a volume heat source, let's call this function my_heat(x,y,z), where x,y,z are comsol spatial variables.
Everything works fine with this (comsol passes x,y,z vectors and matlab returns heat source values based on this, and the model is set up and solved)
Now, I tried to use some global MATLAB variables within the 'my_heat' function. When I run function in MATLAB the variables and their values are accessible in 'my_heat'. However, when the same function is called by COMSOL as part of setting the physics, it seems 'my_heat' does not recognize these variables.
I think I know what the problem is, but don't know the solution to it:
When the model is run from Matlab, Comsol seem to open another instance of MATLAB (as manifested by a second command window). This seems like the place where all the Comsol/Matlab interfacing happens. No wonder that in this new instance of Matlab, the information about any global variables in the main Matlab window is missing.
Any ideas on how to 'pass' all the info from the main Matlab window to this auxiliary one?
Robert
P.S.: On an unrelated note, I discovered that by typing 'clear functions' in this new matlab window, I can have comsol get the updated version of any edits to my matlab fuinctions. Without this, comsol only has the first version of external functions. Typing 'clear functrions' in the main matlab window doesn't maker any difference.
4 Replies Last Post 16 août 2016, 02:56 UTC+2
Hello Robert Furstenberg
Posted: 1 decade ago 3 mai 2012, 07:52 UTC+2
I have the same problem,
could you find a solution no need for storing data into a file and loading them from m-file function?
I have the same problem, could you find a solution no need for storing data into a file and loading them from m-file function?
Posted: 1 decade ago 11 déc. 2013, 22:54 UTC+1
I have the same problem now.
Did you finally solve this issue?
I have the same problem now. Did you finally solve this issue? Thanks
Posted: 1 decade ago 25 févr. 2014, 16:04 UTC+1
Was any one of you able to solve this problem? If you could kindly guide me!
Hi, Was any one of you able to solve this problem? If you could kindly guide me! Thanks,
Posted: 9 years ago 16 août 2016, 02:56 UTC+2
You can store the value to a txt file
