calculate the rate of heat transfer for hollow cylinder????
Hi every one,
im quite new to Comsol 4.1 and i hope you can help me.
I try to calculate the rate of heat transfer for hollow cylinder.Inner temp 573 k and outer temp is 323 k and dimensions is ro=0.5m,ri=0.01m,l=1 m. now i have some trouble in find the correct path in comsol to find the rate of heat transfer. now i am using surface integration menu under post processingto find the rate of heat transfer...my path is correct or not?????
thanks, best regards
parma
1 Reply Last Post 26 déc. 2011, 23:09 UTC+1
Posted: 1 decade ago 26 déc. 2011, 23:09 UTC+1
check
www.comsol.eu/community/forums/general/thread/25065/
if you do not want the heat flux but the poser you need to integrate over the area indeed with an integration operator.
But in anycase, to get an abolute value, I suspect you need to define the heat conduction of your material, no ?
Hi check http://www.comsol.eu/community/forums/general/thread/25065/ if you do not want the heat flux but the poser you need to integrate over the area indeed with an integration operator. But in anycase, to get an abolute value, I suspect you need to define the heat conduction of your material, no ? -- Good luck Ivar
