Parallel wires in infinite air
Posted 27 déc. 2011, 06:07 UTC−5 Low-Frequency Electromagnetics, Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 4.2a 1 Reply
hi All,
i have difficulty to exactly define the boundary condition of my model.
it's about parallel wires (distance betwen them 1[mm] to 30[mm]). First in 2D. If i dont define the air domain, it's impossible to analys interaction of both wires, right? (maybe with boundary pair will work somehow, but i never try this).
Boundary between cable isolation and air is OK, it's not necessary to define anything.
outer boundary of air is a problem.
1. Air is a fluid but air is also an infinite elements. this domain condition (heat transfer in fluids and infinite elements) override each other (sorry my english is overrided by german).
2. then i tried using infinite elements as domain condition and convective cooling as outer boundary condition. The result seems to be correct, but im not sure how to analiticaly validate it.
3. heat transfer in fluids and convective cooling are bad combination.
4. heat transfer in fluids in conbination with open boundary and outflow are wrong. because the temperatur in the midle of wires is the same (at 1mm-30mm wire distance)
5. heat transfer in fluids in conbination with temperatur and outflow are working and looks like the best combination. but im not sure.
please suggest me something. the model is attached.
happy holiday!
akmal
happy holiday!
akmal
1 Reply Last Post 28 déc. 2011, 04:30 UTC−5
