                                5 janv. 2012, 10:23 UTC−5
I'm not sure that COMSOL is the best for what you describe, it sounds more like a multi-body simulation à la Modelica.
www.modelica.org, or via one of the commercial ones as MapleSim)
But to study locally the "contact, friction and slip", I would say COMSOL is better
(www.modelica.org, or via one of the commercial ones as MapleSim)
                                Nagi Elabbasi
        Facebook Reality Labs
                                5 janv. 2012, 15:41 UTC−5
                                                    If you want to model the interaction between the rollers then a multibody simulation tool is more suitable as Ivar mentioned. Use COMSOL if you want to model the interaction of the rollers with a flexible material (the extruded material in your case). You should model the rollers as rigid (very stiff) surfaces with prescribed rotation. In that case only model the rollers in contact with the softer material, and drive each roller independently, if possible.
Here is a link to a paper I presented at the 2011 COMSOL conference that involves rollers; it has some modeling details that you may find useful:
www.comsol.com/papers/11574/download/elabbasi_paper.pdf.
Nagi Elabbasi
Veryst Engineering
Here is a link to a paper I presented at the 2011 COMSOL conference that involves rollers; it has some modeling details that you may find useful: www.comsol.com/papers/11574/download/elabbasi_paper.pdf.
Nagi Elabbasi
Veryst Engineering
