Different positions different peak value
Posted 15 janv. 2012, 15:24 UTC+1 RF & Microwave Engineering Version 4.2 1 Reply
I was about the simulate a sensor application.
It is a simple case. It only contains a sphere and a block. I put the sphere as the environment and the block as a chip antenna.
The material of both are air.
The problem is, when I put the block at (0,0,0), the peak electric field would be about 30, but when I put the block at (0,0,0.25), the peak electric field declines heavily, and even worse when the block is placeD at (0,0,0.5). But I think the peak value should not change when I change the position of the block. There are no other parameters to affect this result.
I hope someone could help. Thanks.
1 Reply Last Post 7 févr. 2012, 04:11 UTC+1
