Help for insulated glass
hello
im trying to simulate simple insulated glass in 3D (glass-air-glass (closed by any silicon)), but i cant get any results.
could you please give me any advise what i have to pay attention?
1 Reply Last Post 19 janv. 2012, 06:59 UTC+1
Posted: 1 decade ago 19 janv. 2012, 06:59 UTC+1
FSI models are tricky, they are complex multiphysics and need careful understanding and tweaking, so the best is to repeat several times the different library models until you really understand the different "buttons" you can use: mesh density, material property ranges, time step ranges ...
Hi FSI models are tricky, they are complex multiphysics and need careful understanding and tweaking, so the best is to repeat several times the different library models until you really understand the different "buttons" you can use: mesh density, material property ranges, time step ranges ... -- Good luck Ivar
