I want to simulate induced force by helmholtz coil
I want to simulate how much force is induced to the permanent magnet when I use helmholtz coil and put a permanent magnet in the middle of coil.
However, it cannot be simulated.
I guess the setting about permanent magnet is incorrect.
What I want simulate is just a commercial disk shape magnet.
Like this,
www.kjmagnetics.com/proddetail.asp?prod=D101-N52
I attached my simulation file.
Coul any body help me?
Thank you
2 Replies Last Post 3 févr. 2012, 00:09 UTC+1
Posted: 1 decade ago 2 févr. 2012, 08:56 UTC+1
Why use 2 physics, oyu can keep MF and remove the MFNC, then add a new "ampere law" node in MF for the magnet, define Constitutive Relation to MAgentisation and set 1E6 A/m (or whatever fits your magnet) for the My value. Then add a domain Force calculation on the magnet
This should help ;)
Hi Why use 2 physics, oyu can keep MF and remove the MFNC, then add a new "ampere law" node in MF for the magnet, define Constitutive Relation to MAgentisation and set 1E6 A/m (or whatever fits your magnet) for the My value. Then add a domain Force calculation on the magnet This should help ;) -- Good luck Ivar
Posted: 1 decade ago 3 févr. 2012, 00:09 UTC+1
At first, I appreciate your help.
There was a progress in simulation.
However, I have another question.
In the simulation, even though I changed current density, the force is not changed.
Could you check my model and tell me which one is incorrect?
Thank you so much.
At first, I appreciate your help. There was a progress in simulation. However, I have another question. In the simulation, even though I changed current density, the force is not changed. Could you check my model and tell me which one is incorrect? Thank you so much.
