Particles disappear after releasing
Posted 21 mai 2020, 15:51 UTC+2 Low-Frequency Electromagnetics, Computational Fluid Dynamics (CFD), Particle Tracing for Fluid Flow Version 5.3 1 Reply
Dear all,
I am facing a problem in my model that I've dealing for teh past weeks and connot solve. I am new at COMSOL so any help will be well received.
Basically, I want to model a non uniform particle distribution inside an adhesive joint, having a higher particle concentration in the middle of the overlap area and less at both ends.
I consider iron microparticles, a polyurethane adhesive and aluminium substrates as the materials for this model. To move the particles I apply a magnetic field originated from a permanent magnet that is placed in the middle top of the joint.
In my model I used three modules: - AC/DC Mgnetic Fields, No Currents (mfnc) - to model the permanent magnet - Fluid Flow Single-Phase Flow Creeping or Laminar Flow (spf) - to model the adhesive - Particle Tracing for Fluid Flow (fpt) - to model and release the particles.
Basically, I set to release the particle inside the adhesive randomly at t=1s, but after at t=2s, for example, the particles disappear.... Maybe I have misread somthing or haven't included some parameter, but I can't figure it out...
If anyone can help, I would appreciate. I wanted to attached the model, but it is too big :( maybe via email can work.
Thanks in advance,
Kate
