Creating geometry features with LiveLink for Matlab
What is the most efficient way of cutting a large number (>1000) circles out of a rectangle using LiveLink for Matlab?
I do it in a simple "for"-loop, but the program slows down with an increasing number of circles.
Is there a more efficient way?
Thanks!
4 Replies Last Post 5 juin 2012, 17:24 UTC+2
Posted: 1 decade ago 21 févr. 2012, 21:38 UTC+1
Isnt there a copy array feature in the matla calls, as in the GUI ?
probably it's quicker inside the COMSOL geometrical soler than via a matlb COMSOL link per cercle.
Anyhow, are ther no other way to avoid so many features/entities by some clever symmetry use?
As, your model will become really slow and heavy to handle.
We have some models with 800-900 entities in 3D, but made within the GUI, you need a minute or two to move up and down, and one should turn OFF the default replotting option in the preferences
Hi Isnt there a copy array feature in the matla calls, as in the GUI ? probably it's quicker inside the COMSOL geometrical soler than via a matlb COMSOL link per cercle. Anyhow, are ther no other way to avoid so many features/entities by some clever symmetry use? As, your model will become really slow and heavy to handle. We have some models with 800-900 entities in 3D, but made within the GUI, you need a minute or two to move up and down, and one should turn OFF the default replotting option in the preferences -- Good luck Ivar
Posted: 1 decade ago 16 mai 2012, 01:17 UTC+2
I am trying to do the same thing but with rectangles. how did you do It in 4.2? I was able to make a geometry array of rectangles in 3.5a but I am trying to do it in 4.2 and I am having trouble since it keeps telling me that a variable with that name already exists.
Error in TEDgeom (line 43)
G{i} = geom2.feature.create('r1{i}','Rectangle');
An object with the given name already exists
- Name: r1{i}
did you find a way to create the geometry objects without giving them each a unique name?
Thanks for any advice.
Hello, I am trying to do the same thing but with rectangles. how did you do It in 4.2? I was able to make a geometry array of rectangles in 3.5a but I am trying to do it in 4.2 and I am having trouble since it keeps telling me that a variable with that name already exists. Error in TEDgeom (line 43) G{i} = geom2.feature.create('r1{i}','Rectangle'); An object with the given name already exists - Name: r1{i} did you find a way to create the geometry objects without giving them each a unique name? Thanks for any advice.
Posted: 1 decade ago 16 mai 2012, 15:27 UTC+2
your variable name is probably "i" that is by default sqrt(-1) the complex "i" try using another name and try to avoid to short (1 lettre names)
Hi your variable name is probably "i" that is by default sqrt(-1) the complex "i" try using another name and try to avoid to short (1 lettre names) -- Good luck Ivar
Posted: 1 decade ago 5 juin 2012, 17:24 UTC+2
I have the same question:
I need to create an array of geometry features, like blocks.
I use a simple for loop but it shows an error:
That's the syntax I am using:
for a=1:1:100
b1{a} = geom1.feature.create ('b1{a}', 'Block');
end
Would you mind telling me the correct syntax to create and array of geometry features?
Many Thanks
Hi I have the same question: I need to create an array of geometry features, like blocks. I use a simple for loop but it shows an error: That's the syntax I am using: for a=1:1:100 b1{a} = geom1.feature.create ('b1{a}', 'Block'); end Would you mind telling me the correct syntax to create and array of geometry features? Many Thanks
