Bad scalability
Posted 15 janv. 2010, 06:22 UTC+1 4 Replies
Hello
I just tried how well comsol scale on a multicore processor. And the result is not very good...
The processor is an Intel core i7-975. 4 physical cores or 8 hyperthreaded cores and there are 6 GB of memory. I did the test using Vista 64-bit and comsol 3.5 64 bit.
The model is using the Navier stokes with k-e turbulence model (chns). the convection and conduction(chcc) and Maxwell stefan diffusion and convection (chms). All from the chemical engineering module.
I use the Paradiso solver to solve the time dependent solution (segregated).
Degree of freedom = 142610
I started the software with the -np flag and changed the value from 1 to 8.
The result:
NP Speed up
1 1
2 1.4733
3 1.4702
4 1.6667
5 1.5986
6 1.5606
7 1.5203
8 1.5155
Does anyone know why the result is so bad? I don't expect to get a linear speed up, but using 4 cores the speed up should be a bit higher. I guess it's a good idea to try a different solver? Does anyone have a tips of which solver to use. I don't have the time to test all of them.
The result:
NP Speed up
1 1
2 1.4733
3 1.4702
4 1.6667
5 1.5986
6 1.5606
7 1.5203
8 1.5155
4 Replies Last Post 18 févr. 2011, 12:07 UTC+1
