Plot a solution from a dataset in Matlab (Solved)
Posted 11 juil. 2020, 00:04 UTC−4 LiveLink for MATLAB, API, Results & Visualization Version 5.5 0 Replies
I am using parameter sweep to solve a contact problem. Is there a way to get a plot data structure in the dataset other than the default last one?
Update: The visualization of a plot group is changed by "setting the property looplevel, which controls the solution parameter."
Example:
- model.result('pg1').set('looplevel', 10);
 - model.result('pg1').run;
Hello Behzad Sadrfaridpour
