Electrical currents in porous media
Hello!
I am doing simulation of saturated by water sand rock (porosity 0.35). No flow of water, but on the side borders I am applying eleсtric potential difference. Electrical current pathing through water accumulate temperature raising in the rock.
However I can not combine two modules: Electrical current and Heat transfer in Porous media. Comsol requires heat transfer parameters for rock and water, but electrical parameters - only for rock, without water. It can not do both.
How to solve this problem? Am I using wrong modules?
Thank you!
1 Reply Last Post 5 août 2020, 12:49 UTC+2
Posted: 5 years ago 5 août 2020, 12:49 UTC+2
Ekaterina,
the problem is that the ec physics doesn't know about the porosity. It only sees one homogeneous domain. A workaround may be to adapt the electrical conductivity of the domain to an effective conductivity of the porous material.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Ekaterina, the problem is that the ec physics doesn't know about the porosity. It only sees one homogeneous domain. A workaround may be to adapt the electrical conductivity of the domain to an effective conductivity of the porous material. Cheers Edgar
