Wetted Wall BC
What are the equations for wetted wall boundary condition in COMSOL ? I can not find it. I want to know what exactly happens when you set the contact angle. Is COMSOL using the Navier Slip Length ? Is this a local or apparent contact angle ?
2 Replies Last Post 18 mai 2014, 23:46 UTC+2
Hello Osameh Ghazian
Posted: 1 decade ago 27 janv. 2014, 11:37 UTC+1
I have the same query. Someone please clarify.
Posted: 1 decade ago 18 mai 2014, 23:46 UTC+2
I am trying to simulate droplet break up in microfluidic channel( water in oil), Two phase flow-level set. For wetted wall boundary condition I put pi/4 for 3D model, However for the 1D simulation it doesn't work. in this case if I put 3*pi/4, I get the result for making droplet. What is the correct contact angle for making droplet of water in oil in microfluidic channel?
Hi, I am trying to simulate droplet break up in microfluidic channel( water in oil), Two phase flow-level set. For wetted wall boundary condition I put pi/4 for 3D model, However for the 1D simulation it doesn't work. in this case if I put 3*pi/4, I get the result for making droplet. What is the correct contact angle for making droplet of water in oil in microfluidic channel? Thanks
