Multiple Level Sets in One Model
I am working on a galvanic corrosion model in COMSOL. I have built two different corrosion models based on the in-built application models that are mentioned below-
  1. Corrosion with deposition of product modelled using level set (under_deposit_corrosion.mph)
  2. Localized corrosion using level set (localized_corrosion_ls.mph)
I was wondering if there is a way to combine both these level set models together in order to use level set for both the corrosion and deposition process?
0 Replies Last Post 19 août 2020, 14:20 UTC+2
Hello Parth Bansal
