Inverse Heat Conduction Problem
Posted 15 sept. 2020, 04:44 UTC+2 Heat Transfer & Phase Change, Optimization 0 Replies
Hi everyone,
Has anybody tried modeling inverse heat conduction problem in COMSOL with MATLAB?
I want to model the following: - a material with known surface temperature but unknown thermal properties will be excited by a heat source with known power at a specific time.
How can I do iterative forward solution to identify the most accurate thermal properties of the material by making the difference in the calculated surface temperature and measured surface temperature (experimental) in COMSOL minimal?
Hello Oliver Ramos
