Error in sweep: Failed to evaluate variable "dom"
Posted 21 mars 2012, 05:35 UTC−4 Low-Frequency Electromagnetics, Studies & Solvers Version 4.2a 0 Replies
I'm trying to solve an AC/DC model using electric currents in frequency domain. I want to solve this model for different source positions, hence I try to set up a parametric sweep to change the values of a "Terminal"-Boundary condition.
Within the Terminal I defined the current as: "Ic*(dom==dom_C1)", where dom_C1 is the parameter which is going to change in the models.
However, when trying to solve the model I get the error that Comsol cannot evaluate the variable "dom", which should actually be a predefined variable pointing to a domain or boundary.
So do I use this Variable in the wrong way?
Thanks for your help!
Hello Sebastian Uhlemann
