Evaluate standard deviation of element size h
Magdalena Haaf Certified Consultant
I consider a 3D model with a free tetrahedral mesh. I calculate the average of the element size h via "Derive Values" --> "Volume average". This part works. Now I would like to calculate the standard deviation of the element size, but I couldn't find out how to use the expression correctly. Comsol has already provided the template which I found via "add expressions":
stddev(op, expr) -> Standard deviation of op(expr, ...)
The first argument of stddev() has to be a string due to diverse error messages I got. Does anyone know what I need to write instead of "op"? Thank you for your help.
2 Replies Last Post 28 oct. 2020, 09:56 UTC+1
Posted: 5 years ago 27 oct. 2020, 15:35 UTC+1
Updated: 5 years ago 27 oct. 2020, 15:36 UTC+1
The first argument to stddev() should be the name of an operator.
Some ways to achieve what you want:
  • Add a Nonlocal Coupling intop1 of type Integration to Component > Definitions, update the solution, and evaluate stddev('comp1.intop1',h) in a Global Evaluation.
  • Add a Nonlocal Coupling aveop1 of type Average to Component > Definitions, update the solution, and evaluate sqrt(aveop1((h-aveop1(h))^2)) in a Global Evaluation.
See https://www.comsol.com/forum/thread/40335/standard-deviation-over-a-data-set for a longer explanation.
The first argument to stddev() should be the name of an operator. Some ways to achieve what you want: * Add a Nonlocal Coupling intop1 of type Integration to Component > Definitions, update the solution, and evaluate stddev('comp1.intop1',h) in a Global Evaluation. * Add a Nonlocal Coupling aveop1 of type Average to Component > Definitions, update the solution, and evaluate sqrt(aveop1((h-aveop1(h))^2)) in a Global Evaluation. See https://www.comsol.com/forum/thread/40335/standard-deviation-over-a-data-set for a longer explanation.
Posted: 5 years ago 28 oct. 2020, 09:56 UTC+1
Thank you for your answer! Both ways work for my problem!
