Electrical breakdown or electrical treeing simulation in high voltage solid insulation material
I need to simulate an electrical tree i.e. breakdown path or cracks in insulation material created by the application of high voltage. For which,
  1. I am using AC/DC Electrostatics physics (time dependant).
  2. Define the geometry.
  3. Assign the material to it.
  4. Created a random perturbation (air bubble) into my base material.
  5. Applied the required voltage across the sample according to its breakdown strength.
  6. Added my partial differntial equations for electrical treeing: phase field model.
But the breakdown path/electrical tree doesnot initiate.
Can anyone please guide me in simulating electrical tree (breakdown path) in solid insulation material (Polyethylene). Do I need to add some other module for breakdown detection?
Thanks.
2 Replies Last Post 4 déc. 2020, 18:49 UTC+1
Posted: 5 years ago 2 déc. 2020, 01:37 UTC+1
Updated: 5 years ago 2 déc. 2020, 01:39 UTC+1
I am not aware of any breakdown physics being explicitly included in the AC/DC Electrostatics module. You can compute field strengths, but if you want to model the breakdown process, you will need a much more complicated implementation than merely electrostatics. Perhaps this article will be of interest to you: https://www.comsol.com/release/5.5/plasma-module . See also https://www.comsol.com/plasma-module . I suggest you contact Comsol Support and ask for their specific recommendations..
Posted: 5 years ago 4 déc. 2020, 18:49 UTC+1
Updated: 5 years ago 4 déc. 2020, 19:03 UTC+1
Thankyou sir for your reply. I am using partial differential equations to develop a phase field model for this phenomena as you said "breakdown physics being explicitly included in the AC/DC Electrostatics module" Can it be implicitly developed using phase field model? Under this condition do I need to use any other module.
Thankyou for your time.
Thankyou sir for your reply. I am using partial differential equations to develop a phase field model for this phenomena as you said "breakdown physics being explicitly included in the AC/DC Electrostatics module" Can it be implicitly developed using phase field model? Under this condition do I need to use any other module. Thankyou for your time.
