Edgar J. Kaiser
Certified Consultant
5 years ago
2 janv. 2021, 11:57 UTC−5
The magnetic force is not depending on the density or mass of the object. It would become relevant in case you wanted to calculate the movement of the object, i.e. when you couple the magnetic force with solid mechanics physics.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
5 years ago
3 janv. 2021, 05:20 UTC−5
Thanks for the reply Edgar.
But then is this force not related to F=ma? If not then, could you please help me understand it a bit. I tried reading the module manual but I couldn't understand much. Is it the force on magnetic lines? Will the force on the body be different then?
Edgar J. Kaiser
5 years ago
3 janv. 2021, 06:16 UTC−5
It is a magnetic force. Nothing is being accelerated.
Edgar J. Kaiser
www.emphys.com
5 years ago
3 janv. 2021, 06:40 UTC−5
Thanks again Edgar.
Just one last question please.
Should I assume it to be force on magnetic field lines rather than bulk mass?
Thanks again Edgar.
Edgar J. Kaiser
5 years ago
3 janv. 2021, 16:08 UTC−5
The magnetic force acts exactly on the entity you defined the force calculation on.
Edgar J. Kaiser
www.emphys.com
5 years ago
4 janv. 2021, 04:35 UTC−5
I think it's still not too clear to me. I'll try reading the handbook again to try and understand this.
By the way, thanks a lot for your efforts. Appreciate it.
