Integrating over Poynting vector
Hi, I'm using wave optics module to compute reflection from surface, as a function of reflection angle, in 2D. I have a port on slit condition emitting 10 W/m TE field (0 0 1). I'm integrating using integration coupling operator over the Poynting vector normalized by the input power (P0), on a distance not too far from it. intop1(sqrt(ewfd.Poavx^2+ewfd.Poavy^2+ewfd.Poavz^2))/P0
While some of the energy does not pass the integration line (it's the same length as the port), the result I am expecting is still near 1. However, I'm getting a result much smaller (1e-3). What Should I change to correct this? The integration line does capture most of the wave.
0 Replies Last Post 28 févr. 2021, 09:17 UTC+1
Hello Shai Wissberg
