heat transfer in 3D object with symmetric geometry
Posted 7 mai 2012, 14:51 UTC+2 1 Reply
I am solving a heat transfer problem for a 3D object. The geometry of the object has a pi/6 rotational symmetry about the z-axis. I have solved the problem for the symmetric segment without enforcing any symmetrical boundary conditions in the COMSOL. After solving, I get (x,y,zT) data for the symmetric (pi/6) element. Now I want to remap /transform this data so that I can get the solution for the entire object. This I do in matlab with coordinate transformation of the segment using 3x3 rotational matrix [cos(phi) sin(phi) 0; -sin(phi); cos(phi) 0; 0 0 1]. Here, phi = pi/6 is rotation angle about z-axis. By performing the coordinate transformation on successive segment 6-times, I can generate the data for the entire object. I am not quite sure if this procedure is correct. In other words, is it true that the geometric symmetry in the object also leads to symmetrical solution of the problem?
R.K.
R.K.
1 Reply Last Post 7 mai 2012, 15:12 UTC+2
