Magnus Ringh
COMSOL Employee
5 years ago
23 mars 2021, 05:07 UTC−4
If the material property does not dependent on temperature, you can use it in a PDE coefficient as mat1.def.Cp, for example, which represents the heat capacity in a material with the name mat1. If there is a temperature dependence, you can define a parameter for the temperature and pass that or a numerical value as an argument for the temperature, when it is not a dependent variable T that you solve for.
Magnus Ringh
If the material property does not dependent on temperature, you can use it in a PDE coefficient as `mat1.def.Cp`, for example, which represents the heat capacity in a material with the name `mat1`. If there is a temperature dependence, you can define a parameter for the temperature and pass that or a numerical value as an argument for the temperature, when it is not a dependent variable `T` that you solve for.
Magnus Ringh
