15 mai 2012, 14:19 UTC+2
I'm not sure I catch you correctly but with COMSOL, most variables are fields defined per f(x,y,z,t), only global variables (integrated over dx,dy,dz hence only F(t)), are available everywhere.
but perhaps you are looking for a custom defined dependent variable, in chich case you must add a ODE or a weak expression
17 mai 2012, 12:10 UTC+2
hi Ivar ,
i have tried doing that , i added a PDE(c) defining 'u' such that du/dt = (T>=T_vap) and then used this variable 'u' to calculate material properties for example Cp_steel*(u==0)+Cp_air*(u>0) , but as soon as u>0 (initial value of u was 0 ) , the material property for every element became the same which i don't want . I want that u should be calculated at every node just like Temperature.
i hope i am able to explain my problem.
- Hirendra
hi Ivar ,
- Hirendra
17 mai 2012, 13:44 UTC+2
still I do not catch your formulas, probably because for me "u" is a reserved variable name of COMSOL for solid and CFD and other physics. You should try to avoid all single letter variable nemaes, most are already used by COMSOL
Then you must define the PDE as a domain equation and not a global equation, your variable should be a field u(x,y,z,t) and not just u(t)
18 mai 2012, 07:50 UTC+2
Thanks a lot Ivar :) after using domain ODE i got the results .
I would like to know how can i make my problem converge faster , any tips ?
Thanks once again
- Hirendra
Thanks once again
- Hirendra
18 mai 2012, 09:55 UTC+2
often by starting with initial value closer to the result, the solver gets their quicker, but its a type of chicken an egg loop
