magnetic field physics related problem
Hello I have some trouble getting the right coil voltage and coil current under the magnetic field physics. I used assembly geometry because the system in my model is complex and there are lots of inner connections. In order to make magnetic field work, I used continuity under "magnetic field" physics and made the **coil+former+vessel as a continuous entity **that is grouped together and seperated from air so that I can apply magnetic insulation boundary condition to the air.
Even though I got some results, the coil voltage and current seem to be off. With results shown after computation, the coil current has been indicated on all the parts in the model (even the air domain!). Any idea what is going on?
1 Reply Last Post 8 avr. 2021, 21:23 UTC−4
Posted: 5 years ago 8 avr. 2021, 21:23 UTC−4
I suggest that you post your model to the forum.
