Modelling Nanoparticle In Ultrasound FIeld
Posted 9 avr. 2021, 14:58 UTC−4 Charged Particle Tracing, Acoustics & Vibrations Version 5.6 0 Replies
Using the pressure acoustics module, I defined my ultrasound transducer as a flat line at the bottom of a water tank and applied normal displacement to generate the pressure field.
I now want to add gold nanoparticles to the simulation and attempt to model the temperature (using the bioheat trasnfer module) and the acoustic radiation force (using the particle tracing module) at the nanoparticle surface.
Does anyone know if this the best course of action is to achieve this? Can I even calculate acoustic radiation force at the nanoparticle surface using the particle tracing module?
Hello Ken Halverson
