Re-starting a simulation with a different geometry
Posted 10 avr. 2021, 14:40 UTC+2 Chemical, Computational Fluid Dynamics (CFD), Geometry 0 Replies
Dear all,
I have a case where a deforming geometry is running time-dependent. At a certain time I need to stop the solution, copy the solution at that point. Then, I need to re-start the model with a slight modification of the original geometry, but taking the copied solution from the previous cases as a starting point. Is it doable in COMSOL?
Best regards, NP
Hello Natan Padoin
