More domains generated once elements exceed 32 by 32
Posted 17 mai 2012, 19:12 UTC+2 2 Replies
Dear all,
I am modeling a panel with 40 by 40 holes. I use Block to get the 3D panel, and use Cylinder and Array to get 40 by 40 cylinders in the panel. But when I define the material properties of the solids, I found one more block solid was generated automatically. I try many times and find that once the numbers of the cylinders exceeds 32 by 32, the unexpected solid domain was then appeared. Therefore, I can not mesh the object once more.
Are there somebody faced this problem before?
I use COMSOL 4.2, this problem bother me for several days, I am looking forward to get help to this.
Thank you very much!
Baofeng
Baofeng
2 Replies Last Post 17 mai 2012, 21:55 UTC+2
