Coplanar stripline
Hi all,
I'm fairly new to COMSOL and am trying to simulate a coplanar stripline. My current issue is trying to figure out how to set up the ports for the simulation. Is there a particular way you would do this? On thing to take into consideration is that I am not including a ground plane below the substrate.
Best, Daniel
1 Reply Last Post 22 avr. 2021, 00:43 UTC+2
Posted: 4 years ago 22 avr. 2021, 00:43 UTC+2
Updated: 4 years ago 22 avr. 2021, 00:47 UTC+2
See the cpw_bandpass_filter example in the Application Library, Under RF Module, Filters. You should be able to make an adaptation of the methods illustrated there. You can read about it in detail at https://www.comsol.com/model/download/824371/models.rf.cpw_bandpass_filter.pdf . Also, see https://www.comsol.com/blogs/modeling-coplanar-waveguides/
See the **cpw_bandpass_filter** example in the Application Library, Under RF Module, Filters. You should be able to make an adaptation of the methods illustrated there. You can read about it in detail at https://www.comsol.com/model/download/824371/models.rf.cpw_bandpass_filter.pdf . Also, see https://www.comsol.com/blogs/modeling-coplanar-waveguides/
